2005 Dodge Caravan Automatic Door Locks
69,000 MILES • 6 CYL • FWD • AUTOMATIC
CHRIS HILL
The locks on this vehicle automatically lock once you reach 10 mph, approximately. They are not doing that now. The door lock switch inside the vehicle that automatically locks all doors when pushed no longer locks the doors either. The remote that locks the doors when you push the button does not lock the doors either. The only way is to manually lock each door. What could the problem be and how is it repaired?
Aug 1, 2008 at 3:15 AM
RISROCKS
I had the same problem. Then I left the key on over night and the battery went dead. After charging the battery the locks all started to work just fine. I would try and disconnect the battery and see if it will reset what ever it is. I have no idea how long it takes but overnight worked on my van.
Nov 5, 2018 at 9:27 AM
