2005 Dodge Caravan Automatic door locks
63,000 MILES • 6 CYL • FWD • AUTOMATIC
AMERICANMAN
Just all of a sudden, the auto door locks will not work. The horn chirp goes off when pressing the lock button on the remote, but nothing else happens. Even pushing the master lock switch on the driver's side door will not lock them. I checked the fuse panel but nothing is related to the door locks. I checked the manual and the only thing said there was how to disable them. When checking if that were the issue, I found in the instrument display two codes P0513 and P0406. Are these of any telling consequence? I'm usually pretty good at diagnostics, but this one has me stumped.
Jun 24, 2008 at 1:45 PM
MURPHY47025
Pull out iod fuse for 5 seconds that will reset the computor and it should work for how long? I have had the same problem and it has helped
Jul 11, 2008 at 11:20 AM
