2005 Dodge Caravan ABS Light On
61,250 MILES • 6 CYL • FWD • AUTOMATIC
BWATSON19
The ABS light has come on. I hooked a Nemysis scanner to it to pull the codes and none were stored. I reset the light and as soon as I get over 10MPH it comes back on. I have been a Automobile Technician in the USAF for 15 years and never have run into this problem. I am looking into replacing the ABS unit but its a bunch of money wasted if its not bad.
May 5, 2009 at 6:32 AM
BMRFIXIT
  • 19,053 POSTS
check ABS unit connector for water or moisture
Suspect a wheel speed sensor 1st
get ABS data reading watch each wheel speed as you driving they all should be the same
when light is on you should be able to get the ABS code
good luck
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
May 5, 2009 at 1:33 PM
