2005 Dodge Caravan 2005 dodge caravan trans axle
2005 DODGE CARAVAN
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAY SCHMITT
I drive my caravan everyday 35 miles to work and most of the way i'm driving up hill on an incline.My van started to jump from drive to passing gear erraticly and I have to slow down so I don't blow the transmission.At times now I have to slow down to let the trans mission shift.I took it to a transmission place to have it checked and they had a hard time to get it to shift erratic,but they did.I never had a check engine light come on to show any codes.They said with out any codes all they can do is quess so they dropped the pan and found only small amount of metal shavings and clutch material.so they said they didn't think the transmission was bad but believe it was the torque converter,does this sound right to You.
Oct 10, 2010 at 7:36 AM
  • 110,240 POSTS
Like they said, without the check engine light, it becomes a guessing game. It could be a torque converter and a few other things, governor, shift modules, trans control module, wiring issue... That is something they should check before just replacing the converter.
let me know if you have other questions.
Oct 11, 2010 at 12:24 AM
