2005 Dodge Caravan
2005 DODGE CARAVAN
48,699 MILES • 6 CYL • FWD • AUTOMATIC
RJB57
Have a problem no park or neutral...when moving the shifter it skips over neutral and goes to D and putting it to park it only goes to R won't go into park any suggestions
Jul 18, 2010 at 9:51 AM
  • 110,244 POSTS
Are you able to crank the engine? As far as the shifter, there is a switch on the transmission that sends a signal to show you what gear the transmission is in.
Jul 20, 2010 at 5:57 PM
RJB57
when the key is in the ignition you can tell what gear it is in but it wont go into P or N -- can't crank it over but when it does go into P or N it will start --you shut it off and then it wont go into P or N again???? Could this be part of the anti theft system??
Jul 21, 2010 at 9:02 AM
  • 110,244 POSTS
I don't think it has to do with the anti theft. It sounds like there is a problem with the park lock solenoid. This may sound really stupid, but are the brake lights working properly?
Jul 21, 2010 at 4:18 PM
RJB57
No problem with the brake lights or flashers, turn signals they are all working properly.
Jul 22, 2010 at 8:09 AM
  • 110,244 POSTS
I realize that sounded like a stupid question, but the park lock solenoid is actuated by the brake light switch. If it is bad, it won't come out of park. The last things left are the park lock solenoid itself or a wiring problem to it.
Jul 22, 2010 at 4:26 PM
