2004 Dodge Caravan Window
MILSON20225
2004 Dodge Caravan
We have a 2004 dodge grandcaravan SXT and the drivers side window will not go up or down. Do you have any quick fix solutions as we don't want to have to replace the motor for it.
Thanks
Matt and Diana
Jan 22, 2010 at 4:16 AM
STEG0687
  • 5 POSTS
[quote:b908352b66="milson20225"]2004 Dodge Caravan
Thanks
Matt and Diana[/quote:b908352b66]
Most likley you will have to replace the motor/regulator assembly. If you get lucky you can hold the button up or down and bang on the middle of the door panel on the inside of the car. Sometimes this works and sometimes not. If it does work I recommend getting the window fully closed and leaving it there untill you can put a new motor in it.
Feb 11, 2010 at 9:49 AM
