2004 Dodge Caravan Slight vibration on break pedal when app
TNELLES
Brakes problem
2004 Dodge Caravan 6 cyl Wheel Drive Type unknown Automatic 80000 miles
Hi there, I just started to get a slight vibration on the brake pedal when braking as well as a humming noise. The noise almost sounds like I'm pushing the gas pedal.
Jan 31, 2008 at 3:40 AM
BMRFIXIT
  • 19,053 POSTS
[quote:5549777901="tnelles"]Brakes problem
Hi there, I just started to get a slight vibration on the brake pedal when braking as well as a humming noise. The noise almost sounds like I'm pushing the gas pedal.[/quote:5549777901]
check wheel bearings /front end
check brake and resurface/replace rotors
Feb 3, 2008 at 11:46 AM
