2004 Dodge Caravan radiator hose
49,000 MILES • 6 CYL • 2WD • AUTOMATIC
TACTICS
What is the metal part of the lower radiator hose called ??? There is a rubber hose that comes off the radiator (not very long) and right into a metal tube that goes under a/c compressor and then up to the water pump, I'm guessing. Mine is leaking and needs to be replaced. (the metal tube) If anyone has attempted this, what am I in for ???
Dec 28, 2008 at 5:27 AM
  • 110,248 POSTS
Hi:
On the radiator, you may find a 1/2 inch or 5/8 inch hose (rubber) that runs to steel, but it will be the trans cooler lines. Can you describe what you see? If possible, could you take a picture and up load it for me so I can see what you are dealing with?
Jan 1, 2009 at 6:28 AM
