2004 Dodge Caravan Power Windows
11,310 MILES • 6 CYL • 2WD • AUTOMATIC
JTROTT13
Both front windows are not working. The vents do. The fuse is good. The switch is good. I switched it with another. My question is if the window motor on the drivers side fails would that open the circuit to the passenger side also?
Aug 22, 2010 at 8:21 AM
  • 110,251 POSTS
A bad motor won't do that. Have you checked to see if there is power to the switch?
Aug 23, 2010 at 5:13 PM
JTROTT13
There is power to the switch and motor when the switch is operated. No power to the passenger side switch though.
Aug 24, 2010 at 12:04 AM
  • 110,251 POSTS
If there is power to the motor, it must be bad. As far as the passanger side, if there is no power to the switch, have you checked the wiring?
Aug 24, 2010 at 12:49 PM
