2004 Dodge Caravan Oil leaking
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
CINCYICEMOM
I have a 2004 Dodge Caravan that is leaking oil.
My mechanic has been working on it for a while and has determined- short distance it does not leak- but long distance it leaks. He is unable to find where it is coming from. We recently had the van worked on. It was only firing on 3.5 cy. instead of 4. We realized that the leak was noticed after we got the van back. Do you have any ideas?? Need help badly.
Oct 15, 2009 at 8:43 AM
CH112063
  • 1,320 POSTS
[quote:9f9e96d096="cincyicemom"]2004 Dodge Caravan 4 cyl Two Wheel Drive Automatic 115000 miles
My mechanic has been working on it for a while and has determined- short distance it does not leak- but long distance it leaks. He is unable to find where it is coming from. We recently had the van worked on. It was only firing on 3.5 cy. instead of 4. We realized that the leak was noticed after we got the van back. Do you have any ideas?? Need help badly.[/quote:9f9e96d096]
Oct 15, 2009 at 8:47 AM
CH112063
  • 1,320 POSTS
[quote:2b34782e53="cincyicemom"]2004 Dodge Caravan 4 cyl Two Wheel Drive Automatic 115000 miles
My mechanic has been working on it for a while and has determined- short distance it does not leak- but long distance it leaks. He is unable to find where it is coming from. We recently had the van worked on. It was only firing on 3.5 cy. instead of 4. We realized that the leak was noticed after we got the van back. Do you have any ideas?? Need help badly.[/quote:2b34782e53]
