2004 Dodge Caravan Odd car door problem
CALGARYD
Shakes or Wobbles problem
2004 Dodge Caravan 4 cyl Front Wheel Drive Automatic 80K km miles
I have auto windows. I discovered 2 smears of a substance that seemed like a lubricant, clear, kind of resembled vaseline on both sides of the window - the smear started at a point 75% up the window and dragged down, looks like it was made inside the door and then smeared when the window was raised. Also, now, when I try to lower or raise the window a screeching/grinding noise accompanied by window/door vibrations occurs.
What is wrong? Has something broken inside the door? Thank you for any help.
Mar 25, 2009 at 6:51 AM
CARADIODOC
  • 34,416 POSTS
To save weight, the window mechanism has been changed from a fairly reliable mechanism to a cable and series of pulleys. The pulleys are plastic. What else can be said? They're plastic.
I suspect you're hearing the cable grinding across the peg that held a pulley. The grease probably came from the cable. We used to use a silicone lubricant on the window channels to make them slide freely, but that evaporated in a few minutes and the residue did not migrate to other parts.
caradiodoc
Mar 27, 2009 at 10:53 PM
