2004 Dodge Caravan fuse
JAY8397
Electrical problem
2004 Dodge Caravan 6 cyl Two Wheel Drive Automatic
radio and cigarette lighters not working. i have checked the fuse box under the hood and none of the fuses are blown. i there another fuse box? i checked inside the drivers door and under the steering wheel. the manual says the only fuse box is under the hood and if you have any related issues to contact a dealer. there has to be a hidden fuse
Nov 30, 2009 at 3:02 AM
JDL
  • 16,098 POSTS
welcome to the forum, no other fuse box, I'm aware of. Use a test lite, check fuse circuit for voltage. Fuse 5 -- 20 amp, in underhood fuse box, integrated power module, whatever they call it. That fuse gets voltage from accessory relay, pull relay, use test lite, two terminals should be hot all the time.
Nov 30, 2009 at 3:16 AM
