2004 Dodge Caravan Front Blower
74,000 MILES • 6 CYL • FWD • AUTOMATIC
THEGOSHES
The front blower on the van is not working. I have checked the fuse and the relay and both are okay. The blower in the rear of the fan is working fine. Any suggestions as to what is wrong with the front blower and how I can fix it?
THANK YOU!!
Chad
Jan 10, 2009 at 5:03 AM
BMRFIXIT
  • 19,053 POSTS
Locate the blower motor and unplug it connector
turn key on and place the fan switch on high
check at the connector wire for power and ground if you have both remove and replace the motor if not let us know what is missing
good luck
Jan 10, 2009 at 6:05 AM
JDL
  • 16,098 POSTS
I'd get at the blower motor connector, run a couple of jumpers for B+ and ground, use an inline fuse, see if the motor will run.
You might be able to get at the connector by removing the glove box.
The resistor and hvac control module, control the ground side of the blower motor. No ground, no blower activity. Yes, you need voltage also.
Jan 10, 2009 at 6:28 AM
