Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine Cooling
Cooling Fan
Relay
2004 Dodge Caravan cooling sensor
2004 DODGE CARAVAN
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARL GENE WILLIAMS
MEMBER
1 POST
where is the cooling sensor for the fans located on the motor;
Where is the relay for the fans located
Aug 10, 2010 at 3:48 AM
JDL
Experienced Mechanic
Found this info in our database. If your not sure which sensor is which, look at the wiring colors. I cannot guarantee the accuracy of database.
Aug 10, 2010 at 4:50 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
