2004 Dodge Caravan coolant leak
CRONYJABRONY
Engine Cooling problem
2004 Dodge Caravan Two Wheel Drive Automatic 130000 miles
It is leaking half way down the van on the passenger side. Cant figure out where its coming from. Just little puddles of green. Any help would be appreciated
Jan 13, 2009 at 6:36 AM
  • 110,244 POSTS
Hi:
It sounds like the water pump. There is a weep hole behind the pulley. When the bearing in the pump goes bad, it will leak from there. See if you can find it and check if there is evidence of a leak.
Let me know what you find.
Jan 13, 2009 at 7:10 AM
