2004 Dodge Caravan ABS problems
102,000 MILES • 6 CYL • FWD • AUTOMATIC
MARCUS_01
I have a 2004 Dodge Grand caravan SXT. Recently my ABS light on the dash has come and stayed on. I also lost the traction control due to the light being on. Last time this happened, it was a frozen sensor. So this time I've parked inside for a couple of days, removed the wheels and sprayed hot water to melt the snow and ice. After all was done I removed the battery to reset the computer. Still today the light is on, with no ABS or traction control. What else could it be??
Thanks,
Jay
Feb 3, 2008 at 1:10 AM
BMRFIXIT
  • 19,053 POSTS
[quote:8cb0e4dd9e="marcus_01"]Brakes problem
2004 Dodge Caravan 6 cyl Front Wheel Drive Automatic 102000 miles
Thanks,
Jay[/quote:8cb0e4dd9e]
With ABS system you need to have system scanned
you can check brake fluid and brake light switch
codes will point you in the right direction
Feb 3, 2008 at 11:18 AM
