2004 Dodge Caravan 2004 Engine Light Blinking
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
WESTSS
My engine shakes and bucks and my Check Engine Light Blinks. I removed my spark Plug Wires one at a time and have no spark on wire 4 and 3. Is this my coil and how do I remove it if it is? Is there a way to test the system with out a scanner?
Jan 8, 2010 at 5:48 AM
CH112063
  • 1,320 POSTS
Which 6 cylinder do you have in your mini-van? Each coil pack can be tested using an ohmmeter, but its best to use a scanner, ok? each engine may have different resistance specs. They can be found in the service manual. Why not see if you can find yours here they have em all, ok? A scanner is very cheap at the store and you'll use it for a long time, it'll save you money.
Jan 8, 2010 at 11:10 AM
