2004 Dodge Caravan
POOHH35
  • 2004 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 76,000 MILES
When driving my van the rpms are high and it doesn't move to the next gear
Monday, February 8th, 2010 AT 11:34 AM
CH112063
  • 1,320 POSTS
Your describing a van that is slipping into nuetral while your in drive, at high speeds. Is the transmission fluid ok? If it is full you may have a trans filter that is clogging or a problem internally. You will have stored fault codes in the TCM that will help you find what is causing this. Ok
Monday, February 8th, 2010 AT 8:01 PM
