2003 Dodge Caravan winshield washer not spraying
ROSSNEILSEN
2003 Dodge Caravan 6 cyl Front Wheel Drive Automatic
hi
my front windshield washer fluid all of a sudden will not spray. the back one still sprays. is there a fuse? is there a motor?
thanks
Feb 17, 2009 at 3:10 AM
DOCFIXIT
  • 18,828 POSTS
Motor on bottom of fluid resivore
Feb 17, 2009 at 5:17 AM
ROSSNEILSEN
is there a fuse i should check first?
Feb 17, 2009 at 5:24 AM
DOCFIXIT
  • 18,828 POSTS
Check fuse #33 in the ICM left front engine compartment.
Feb 17, 2009 at 5:43 AM
ROSSNEILSEN
thanks for the fuse tip.
last question:
does the rear sprayer run on a separate motor or the same one as the front?
Feb 17, 2009 at 7:56 AM
DOCFIXIT
  • 18,828 POSTS
Different motor
Feb 17, 2009 at 8:52 AM
