2003 Dodge Caravan will not start
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
MATTHEW BOSKO
the van shutdown win we were driving .
towed it home and the fuel pump fuse was blown changed it and started it again and it ran a little and blow again we did this 3 times then it stopped but the fuse did not blow we tryed to start it again and it would not turn over. no blown fuses i changed the fuel pump and filter and looked for a short no luck I also changed the battery
Jan 29, 2008 at 10:32 AM
  • 75,988 POSTS
If it has one checked the ASD relay and also the fuel pump relay. The ASD powers the coil/injectors and fuel pump through the fuel pump relay. Double check the fuel pump wiring for a short.
Jul 20, 2018 at 8:45 AM
