2003 Dodge Caravan wet leak
108,000 MILES • 6 CYL • FWD • AUTOMATIC
SKIP SHIPWASH
I have recently discovered the carpet and padding soaking wet on passenger side of vehicle. I assumed the drain tube was clogged so I ran a wire up a short rubber hose on firewall side. It seemed to go the length of the hose 4-5 inches and stopped. Sometimes when you first crank the car you can hear a swishing water sound in the dash area. I think there may be some other problem than just a clog. Any suggestions? Skip
Jun 8, 2008 at 3:36 AM
OBXAUTOMEDIC
  • 3,718 POSTS
[quote:12a7807459="Skip Shipwash"]Air Conditioning problem
2003 Dodge Caravan 6 cyl Front Wheel Drive Automatic 108000 miles
I have recently discovered the carpet and padding soaking wet on passenger side of vehicle. I assumed the drain tube was clogged so I ran a wire up a short rubber hose on firewall side. It seemed to go the length of the hose 4-5 inches and stopped. Sometimes when you first crank the car you can hear a swishing water sound in the dash area. I think there may be some other problem than just a clog. Any suggestions? Skip[/quote:12a7807459]
Well if drain appears clear then the only other thing is the Heater Core. You could also check the Hose connection make sure they are tight and not leaking.
Jun 8, 2008 at 2:35 PM
