2003 Dodge Caravan Struts, Sway-bar Links
272,000 MILES • 6 CYL • FWD • AUTOMATIC
PC_GRAFIX
Vehicle service records indicate that the sway-bar links have been replaced 3 times since 2007.
What is the underlying cause?
Would replacing the struts & mounts eliminate this, or is something else going on?
Jun 13, 2010 at 12:18 PM
  • 110,248 POSTS
It is common for them to go bad, but that seems extreme. Have you personally checked to make sure that is the problem? Are they loose? Also, new struts won't prevent this from happening. Make sure they are bad before they are replaced. If you hear a noise, many times it is the lower control arm bushings.
Jun 14, 2010 at 4:51 AM
PC_GRAFIX
according to Midas, everything but the struts 'is fine', but i have a feeling that more is going on
Jun 14, 2010 at 1:07 PM
  • 110,248 POSTS
Here is a simple test. Bounce the front of the vehicle. If it stops bouncing within 3 bounces, the structs are good. If that is the case, I would recommend a second opinion. If I was there, I could tell you right away.
Jun 16, 2010 at 3:05 PM
