2003 Dodge Caravan running rough
42,532 MILES • 6 CYL • FWD • AUTOMATIC
WORK1278
Van running very rough almost like on 3 cylinders. Hooked up to OBDII auto scanner and the code P1297 Fuel Meter Control was noted as well as PO300, PO305 & PO306 misfire. I would like to know what I can do to fix this.
Jan 15, 2010 at 10:32 PM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 15, 2010 at 10:35 PM
