2003 Dodge Caravan replaced engine
73,000 MILES • 6 CYL • FWD • AUTOMATIC
THEBUHLS1
This may be more than you wont to take a stab at but i changed the engine in my 03 grand caravan the old one started knocking. the replacement will not start. I changed the: coil pack, plugs and wires from the old engine because i know they are still good. I tried pulling a plug then putting it in the plug wire it did not fire. I pulled the fuel line loose and it had pressure on it. Do i need to do something to reset the computor? Can the fuel rail or fuel injector go bad setting in the junk yard? any suggestions would be apreciated.
Jul 9, 2008 at 1:24 PM
BMRFIXIT
  • 19,053 POSTS
U listed the parts that was changed
I didnt make if u have fuel pressure or not and if you have spark or not
I would check the crank sensor and ASD relay
Jul 9, 2008 at 1:37 PM
THEBUHLS1
the sensor that looks at the fly wheel was still unpluged thanks
Jul 11, 2008 at 1:49 AM
