2003 Dodge Caravan rear brake drums
84,000 MILES • 6 CYL • FWD • AUTOMATIC
TREVLOCK
The rear brake drums on my 2003 caravan are extremely stubborn and I can't get them off to replace the shoes. There is some corrosion, but the problem lies with accessing the adjuster. We have tried a flat head screwdriver and a brake tool with no success. It appears that there is just not enough room behind the brakes to maneuver the tool or screwdriver in at the right angle. Is there another way or another tool available?
Therese
Sep 27, 2008 at 3:39 AM
MERLIN2021
  • 17,250 POSTS
I use a small flat screwdriver, and a pick to hold the adjusting lever away from the starwheel.
Feb 25, 2021 at 12:15 AM
ERIRISH
  • 5 POSTS
I also found after you get the Shoes backed off a little that there are two small screw holes in the drum it's self that when you screw a screw into it pushed the drum off the hub. I can't remember the size of the screws I used but it worked great.
Good luck.
