Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Caravan
Engine Cooling
Radiator
Leak
2003 Dodge Caravan Radiator Leak?
2003 DODGE CARAVAN
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
JABADRAMO
MEMBER
1 POST
How can I tell if the radiator is leaking?
Jun 23, 2010 at 7:06 AM
Experienced Mechanic
Do you see coolant under the vehicle? If so, where do you see it? Also, does it look like any hoses are loose or leaking? Finally, does the leak seem to be from the passanger side behind the tire?
Jun 23, 2010 at 2:11 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
