2003 Dodge Caravan Power Port Dead
ORCANUS
Electrical problem
2003 Dodge Caravan 6 cyl Front Wheel Drive Automatic
The front power outlet is dead. All other dash components work. The rear power outlet also works. I can not find a blown fuse. Is there an inline fuse? If so where is it and how do I get to it. If not what can be the cause of this problem? Thank you in advance.
Mar 10, 2009 at 6:17 AM
JDL
  • 16,098 POSTS
Check the ptc 7, 13 amp in the integrated power module, underhood. The circuit should be hot all the time. The symbol for the ptc appears to be a circuit breaker.
Mar 10, 2009 at 6:50 AM
