2003 Dodge Caravan Possible bent valve
RYRYMOMMA
  • 7 POSTS
Engine Mechanical problem
2003 Dodge Caravan 4 cyl Two Wheel Drive Automatic
My van has been making a rattleing sound for about a month & has gotten louder over time..last week it started have loss of power when driving under 40 mph & stalling a little at stops..
I was told that it sounds like a bend valve..
What is the cost to repair? is it something my husband can do or sould be take it to a shop?
Jun 5, 2010 at 3:43 PM
  • 110,251 POSTS
Other than the noise, is the engine still running okay? A bent valve will cause a constant miss. Is that what is happening? Also, I want you to take a rubber mallot and tap on the exhaust system to see if the inside of the catalytic converter is loose causing a noise and causing a loss of power. Also, let me know if you can tell aprox where the sound is coming from. NOTE: I need to know the engine size because a bent valve usually isn't a problem with these vehicles.
Jun 5, 2010 at 4:39 PM
RYRYMOMMA
  • 7 POSTS
Yes the engine is running good beside slight loss of power at times & noise.. It is not causing a constant miss. The sound seems the loudest underneath but the engine is so small & compact it's very hard to tell where it is coming from..
It's a 4 cylinder..
My Husband changed the oil & put in SAE 30 & Lucas heavy duty oil stabilizer & it didnt change anything at all..
We'll check the Coverter in the morning.. Thank you!
Jun 5, 2010 at 6:13 PM
RYRYMOMMA
  • 7 POSTS
My husband tapped on the exhaust system & we did hear a faint rattling sound with the car off.. he said it does sound like it is coming from that direction..
Sould I take it to a reg. shop & have it checked out first or straight to a muffler shop? whats the average repair/replacement cost of that?
Thanks!
Jessica
Jun 6, 2010 at 5:39 AM
  • 110,251 POSTS
If you hear a rattel from the converter, it may be loose inside. I would have it checked your regular shop.
Let me know what you find.
Jun 6, 2010 at 11:31 PM
RYRYMOMMA
  • 7 POSTS
It's a very,very loud rattle & it seems to be coming from that area..when we tapped on the exhuast system with the van not running we could hear a very slight rattle..
although I think it seems to be coming from that area I have had my father in law tell me several times he thinks it's coming from my engine..
It started about two months ago when we took a family day trip up to the mountains.. when leaving I heard it.. but it wasnt very loud over time it has gotten louder & louder..it is non-stop when the van is on. Have you heard of this before if it isnt the Cat.Converter what else could it be?
Thank you!
Jessica
Jun 7, 2010 at 2:29 AM
  • 110,251 POSTS
A knocking or ticking could be an internal engine problem. But, although that can lead to major engine problems, usually you don't lose power. That is why I thought maybe the inside of the converter was loose and partially blocking the exhaust. That will cause a power loss.
Jun 7, 2010 at 5:58 AM
RYRYMOMMA
  • 7 POSTS
I had a trusted Mechanic come check it out this morning & he said it is the motor..he said he can replace it for about $1,500 parts & labor.. He thinks its best to get a new motor & not one from a salvage yard..
Your thoughts on used motors?
Jun 7, 2010 at 6:06 AM
