2003 Dodge Caravan p0320 Cranshaft sensor
85,823 MILES • 6 CYL • 2WD • AUTOMATIC
ANGEL70
My caravan 2003 have a problem no start after running and turn off( about 30 minutes)
Scanner to check a problem giving a code p0320.
Proceed to change a cranshaft sensor but the problem continue, the sensor are a replacement part, no original. Please help me to fix this problem, Thank you.
Sep 27, 2010 at 12:56 AM
WRENCHTECH
  • 20,760 POSTS
That code is only telling you that there was an interruption in the Crank Sensor Signal. That can be triggered by anything in the circuit which consists of the Crank Sensor, the PCM (computer), the flywheel and all related wiring. Since the vehicle runs most of the time, this can be difficult to diagnose and will require some technical equipment and will have to be tested only while the problem is present.
Sep 27, 2010 at 1:56 AM
