Engine Cooling problem
2003 Dodge Caravan 6 cyl Front Wheel Drive Automatic
My van overheats when sitting still, does not run hot while traveling. The check engine light came on then the problem started. I checked the obvious, belt, thermostat, fluids, etc. I noticed the electric fans are not turning on. I am assuming a sensor went out that controls the fans. I took the vehicle to AutoZone to have a diagnostic (computer check) for the check engine light. Even though the check engine light is on, the diagnostic read "pass" with no codes registering. Am I correct to assume that a sensor controls the 2 fans? If so, if the computer is not giving a code, how do I know which sensor to replace? Or is there something else that controls the fans functions?
Aug 18, 2010 at 11:58 AM
