2003 Dodge Caravan noise
TERRYRUDIN
Noises problem
2003 Dodge Caravan 6 cyl Wheel Drive Type unknown Automatic 55000 miles
When the temperature falls below 40 degrees our our front end makes a loud continuous noise when steering. We've taken it into the dealer a few times and of course it never happens. In researching the internet I've read it could be the power steering reservoir net, sway bar etc.
Mar 16, 2008 at 9:18 AM
SERVICE WRITER
  • 9,123 POSTS
Is this a moan, squeal, whine?
Mar 17, 2008 at 6:03 AM
TERRYRUDIN
It is a whine noise
Mar 17, 2008 at 9:28 AM
SERVICE WRITER
  • 9,123 POSTS
Has the power sterring reservior been replaced? The ere is a screen that will get clogged/gummed up and cause a lack of flow to the pump and then cavitation occurs. There is a TSB about a sterring shudder from this as well. Once this is replaced, the system needs to be flushed out with ATF + 4 Transmission fluid and filled back up with the same. It is possible damage to the pump may have occured.
This would be my expectation of your whine withourt hearing it. .
Mar 17, 2008 at 9:42 AM
