2003 Dodge Caravan no start
SLIMJIM42
  • 2003 DODGE CARAVAN
  • 6 CYL
  • 60,000 MILES
I have replaced the IAC and the temperature sensor and my van will not start below 40 degrees
Saturday, December 19th, 2009 AT 1:29 PM
BMRFIXIT
  • 19,053 POSTS
Will it start if while cranking stepped on gas a bit?
If so check IAC circuit if not, check it for tune up.
Check if coil have a nice blue and strong spark.
Check fuel for contamination and check fuel pressure.
Was it check for codes?
Friday, July 20th, 2018 AT 3:45 PM
BMRFIXIT
  • 19,053 POSTS
Did he checked for codes?
Does he have a scanner tool that he can check PCM data?
SLIMJIM42
Yes, he checked for codes and not one code came up.
Also there was no check engine light on.
He checked for a bad O2 sensor and on the scanner the pre and post O2 sensor. The pre O2 sensor came up all 0's were the post O2 sensor fluctuated with numbers. So he replaced the pre O2 sensor and it started up right away, but now the check engine light is on! So we now have got the van running, but the check engine light is on. Do you think the post O2 sensor is bad also?
BMRFIXIT
  • 19,053 POSTS
Replacing just one O2 sensor may cause a fault readings as old O2 maybe slow to respond.
First I would do is check for codes.
Let me know what you have for codes.
https://youtu.be/YV3TRZwer8k
SLIMJIM42
Just wanted to tell you how helpful you really are. Yes, the O2 sensor did finally go off.
The code that was taken prior was P0139 and after replacing the O2 sensor is now P0172. So yes it was a delayed, but the check engine light did go off.
Thank you for all your help! I would recommend you guys to anybody.
BMRFIXIT
  • 19,053 POSTS
