2003 Dodge Caravan my Mini won't start
ANGELLEE497
  • 2003 DODGE CARAVAN
Noises problem
2003 Dodge Caravan 4 cyl Two Wheel Drive Automatic
My minivan won't start, everything turns on, lights, radio, ac everything, except it will not start, when I try to turn it on, I hear clicking sounds, (like click, click, click) as I am turning my key to start. Please Help!
Monday, April 13th, 2009 AT 4:39 PM
LEGITIMATE007
  • 5,121 POSTS
Well, check all cables to and from the starter for corrosion or possibly a loose cable. Also try to start it in neutral, if it starts then it is your neutral safety switch. Also, your battery could be slightly under par. I will send you some links to show you how to test for battery voltage. Let me know what happens, please.
Friday, July 20th, 2018 AT 3:45 PM
LEGITIMATE007
  • 5,121 POSTS
https://www.2carpros.com/how_to/battery.htm
