2003 Dodge Caravan key ignition
DENNIS BARTLETT
Interior problem
2003 Dodge Caravan 6 cyl Two Wheel Drive Automatic
Can't get the key to turn on the car some times. Then after a while of trying the key turns and then starts.
Jan 26, 2009 at 5:13 AM
LIONEL S ORTEGA SR
  • 6 POSTS
if your keys worn down it wont work all the time try jiggling it when turning ,if it is try dealership for new cut key cutting key off of old might give you same problem if it continues your ignition may be damaged inside then replacing would be best
Jan 26, 2009 at 5:37 AM
