2003 Dodge Caravan Im getting the p0456 code on 03 grand ca
72,222 MILES • 6 CYL • FWD • AUTOMATIC
RALLEV79
Im getting the p0456 code on 03 grand caravan and have bought and thrown out several gas caps so i dont think that is the problem. many posts say the problem then is most likely the fuel vapor canister but i do not know where that particular part is located and cant find a good schematic online. what do i do to get rid of the code?
May 19, 2009 at 9:07 AM
CARADIODOC
  • 34,413 POSTS
Most shops have a "smoke" machine that can pressurize the evaporative emissions system with two pounds of pressurized non-toxic smoke to find leaks. They might find a cracked vacuum hose or a purge solenoid that isn't closing properly. The loose gas cap is just the most common cause of a leak but by far not the only one.
caradiodoc
May 19, 2009 at 6:10 PM
