HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Climate Control
Heater
Heater Core
2003 Dodge Caravan heater cores
CLAYTON72
MEMBER
2003 DODGE CARAVAN
6 CYL
FWD
AUTOMATIC
107,000 MILES
Is there a front heater core for a dodge grand caravan v6 3.8l
Saturday, February 2nd, 2008 AT 6:24 PM
BMRFIXIT
MECHANIC
You should have two one in the front under the dash in the HVAC box and the other in the rear
Saturday, February 2nd, 2008 AT 8:07 PM
Please
login
or
register
to post a reply.
Related Heater Heater Core Content
Rear Heater Core Delete Procedure
How Do I Do A Rear Heater Core Delete On This Van? The Plumbing Is Rusted Out. I Did Cut Out The Bad Area And Use 5/8 Hose To Repair A...
Asked by
Jamie007
1 IMAGE
2003
DODGE CARAVAN
GUIDE
Heater Core Replacement
A heater core is positioned inside the car and is part of the HVAC system. Hot engine coolant is run through the core which air is blown through via the blower motor which ...
Heater Core Removal
Thinking Seriously About Removing The Heater Core To Inspect Its Condition. Windshield Fogging, Serious Bad Smell Coming From The Vents...
Asked by
karnsem
1994
DODGE CARAVAN
1997 Dodge Caravan Problems In My Heater Core
How Can I Take Off The Old Heater Core From My Van Do I Nead To Remove The Hole Dash Bore Or Can I Take It Off From One Side?
Asked by
frank 03
1997
DODGE CARAVAN
1989 Dodge Caravan Heater Core Replacement
Engine Cooling Problem 1989 Dodge Caravan 6 Cyl Front Wheel Drive Automatic How To Replace Heater Core
Asked by
hickeyj
1989
DODGE CARAVAN
Heater Core Issue
Got Water In Floor Board. I Know Its The Heater Core. Can You Give Me A Diagram On How To Replace The Heater Core And What All Parts I...
Asked by
barbara1963
1 ANSWER
1996
DODGE CARAVAN
VIEW MORE
Heater Hose Replacement
Heater Hose Replacement Chevrolet Camaro
Coolant Leak Symptoms
