2003 Dodge Caravan Gas fumes inside car When Air conditioni
60,000 MILES • 6 CYL • FWD • AUTOMATIC
FUSEBOX3
I am smelling unburned gas fumes in my 2003 dodge caravan when the air conditioning and I think it happens also when the heat is on. It is worse with the air conditioning set to fresh air rather then to recuirculate the inside air. there are no obvious drips on the ground anywhere under the car
Jun 30, 2009 at 9:17 AM
2CARPRO JACK
  • 11,533 POSTS
Have the engine thoroughly inspected for leaks.Look around the injectors to see if any are leaking externally.Have this taken care of ASAP, fuel leaks are nothing to mess with.
Jul 1, 2009 at 1:14 AM
