2003 Dodge Caravan Engine Light Came On
LSAKOTA
2003 Dodge Caravan Two Wheel Drive Automatic 91000 miles
The engine light is on, however I cannot tell that there is anything wrong. The garage states the code reads there's leaking air. (something like ABC Leak). My father-in-law guesses its the charcoal canister? Do you have any idea where to start looking or what could be the problem?
May 20, 2010 at 7:54 AM
  • 75,988 POSTS
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
May 20, 2010 at 1:37 PM
