2003 Dodge Caravan Engine
ENEDELIAGRC
Engine Mechanical problem
2003 Dodge Caravan 6 cyl Front Wheel Drive Automatic
when i turn the key sounds like it wants to start but won't. A few weeks back as i was driving when i stepped on the gas pedal it wouldn't pick u speed & turned off on it's own, somehow it started back-up again just to make it home
Oct 19, 2008 at 9:45 AM
  • 110,248 POSTS
Hi:
Does the engine turn over? If so, the first things you'll need to check for are fuel and spark. If you have never done this before, you may want to have a mechanic do it because checking fuel pressure requires a special tool.
Let me know if I can help you after you've checked these items.
Oct 22, 2008 at 1:57 AM
