2003 Dodge Caravan Driver Power Windows stuck in closed pos
25,000 MILES • 4 CYL • 2WD • AUTOMATIC
ERROL360
Everything works okay if the windows don't go all the way up. Somehow it seems to be stuck, when I pull down on the window, then it goes down after 2 inches. I replaced the whole assembly because the cable went haywire. Also the motor stopped working 2 months ago , then I hit it with the hammer and it was fine till now. I bought the whole assembly from NAPA which is made in China. I sprayed and loosened the tracks. Same thing.
Oct 13, 2008 at 1:24 PM
BMRFIXIT
  • 19,053 POSTS
So you bought a bad part I would think its still warranty from your part store
check with them
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 14, 2008 at 11:11 PM
