2003 Dodge Caravan door
80,000 MILES • 6 CYL • FWD • AUTOMATIC
SHAN1234556
how to open driver-side door pabel. to repair window. its not respoinding. power is there i cheeked when i push button up or down window movers about 1/2 cm. now i want to open the door panel to fix it.
Apr 3, 2009 at 9:04 AM
  • 110,251 POSTS
Hi:
You need to remove the arm rest (screws under plastic plugs), After that, there are a couple other screws around the outside of the panel. Then there are plastic clips behind the door panel that pull off.
NOTE: Make sure you are getting 12 volts to the motor.
Apr 6, 2009 at 4:54 AM
