2003 Dodge Caravan does not engage in gear
2003 DODGE CARAVAN
150,000 MILES • 6 CYL • FWD • AUTOMATIC
BETTYBEE59
I have a 2003 Dodge Caravan. It sometimes does not get into gear, it stays as though it were in neutral. This happens mostly at start up in the morning. I have to push the gas pedal down far and hold it, revving the engine very fast and then it jerks into gear. This happens when starting the car but also a couple times after starting to move too. Especially if moving slowly (as in, through a parking lot) or coasting down a hill. Seems to happen with more frequency as the weather gets colder.
Nov 28, 2008 at 4:24 PM
DOCFIXIT
  • 18,828 POSTS
Check fluid is it dark in color ?Has fluid ever been changed? You need to get to a repair shop because your having a trany melt down.
Nov 29, 2008 at 1:52 PM
