My speedometer and R.P.M on the panel doesn't leave 0. Checked the fuses and disconnected battery and re-hooked it up with no luck.
Mar 1, 2010 at 10:24 AM
BMRFIXIT
✓Experienced Mechanic
Suspect bad cluster/or wiring
cluster failure more common
Use a scanner select DATA start and run the engine do you have RPM
check for IP codes
Mar 1, 2010 at 10:29 AM
