2003 Dodge Caravan Can;t start car
KAPT KRAZY
  • 2003 DODGE CARAVAN
Steering problem
2003 Dodge Caravan 6 cyl Front Wheel Drive Automatic
Car will not start. Steering column locked up. Can;t turn key; Had to tow car. Noticed transmission oil when auto was moved. Could this be Netural Sender switch that goes into trans.
Saturday, September 27th, 2008 AT 2:30 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect ignition cyl key
remove the key and rotate 180*insert key back in and try to rock the steering wheel while turning the key
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Saturday, September 27th, 2008 AT 9:27 PM
