HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Caravan
Engine
Symptoms
Low Power
SPONSORED LINKS
2003 Dodge Caravan accesory belt issue
FRANKWYTE
MEMBER
2003 DODGE CARAVAN
Engine Mechanical problem
2003 Dodge Caravan 4 cyl Front Wheel Drive Automatic
van starts and idles fine without the accesory belt off, but with it on it bogs down and kills. What can be the problem?
Saturday, September 25th, 2010 AT 6:49 PM
OBXAUTOMEDIC
MECHANIC
If it runs fine with Drive Belt off then check all the pulley's they should all spin freely except the very bottom large one (Crank Shaft Pulley).
It sounds like you have a bad pulley bearing does it squeal with belt on?
SPONSORED LINKS
Saturday, September 25th, 2010 AT 7:05 PM
FRANKWYTE
MEMBER
No it doesn't make any unusual noises, it just bogs down and kills
Saturday, September 25th, 2010 AT 7:39 PM
OBXAUTOMEDIC
MECHANIC
Do all the pulley's except for the crank shaft pulley turn freely?
Saturday, September 25th, 2010 AT 7:43 PM
FRANKWYTE
MEMBER
Yes, all the pulleys are working fine
Sunday, September 26th, 2010 AT 2:23 AM
OBXAUTOMEDIC
MECHANIC
Ok, Since putting the belt on creates an extra load on the engine here are a few questions for you.
How many miles are on the vehicle?
When was last tune up?
Is Engine Light on? If so will need to see about getting codes read.
SPONSORED LINKS
Sunday, September 26th, 2010 AT 8:37 AM
Please
login
or
register
to post a reply.
Related Engine Low Power Content
Voltage Light Came On Then Radio Went Out. Then Rpms...
I Have A 2003 Grnd Caravan, 3.3 Flex. I Was Driving On The Interstate When My Voltage Warning Light Came On And Rpm Indicator Went To 3500...
Asked by
wandrwiz
2003
DODGE CARAVAN
VIDEO
Fix an Engine with Low Power!
Instructional repair video
GUIDE
Symptoms of Low Engine Power
The power your car's engine is producing is important. When you step on the gas you need your car to accelerate, mainly to keep you out of trouble when getting onto the...
2003 Dodge Caravan Possible Bent Valve
Engine Mechanical Problem 2003 Dodge Caravan 4 Cyl Two Wheel Drive Automatic My Van Has Been Making A Rattleing Sound For About A...
Asked by
ryrymomma
2003
DODGE CARAVAN
At Times The Van Will Come To An Almost Stall (lose...
At Times The Van Will Come To An Almost Stall (lose Power In Dash, Radio Goes Quieter And The Heater Will Slow Down) When It Slows To...
Asked by
keeley
2003
DODGE CARAVAN
My Van Has No Power Assist When Turning Left When It...
My Van Has No Power Assist When Turning Left When It Is Cold (below 40), But It Comes Back After Warming Up. Another Post I Read On Here...
Asked by
michaeltraver
2003
DODGE CARAVAN
Loss Of Power When Driving
When Driving The Dodge Caravan For About 45min I Will Start To Lose Power When Pushing The Gas I Can Push The Gas Peddal All The Way To...
Asked by
swilder5
2007
DODGE CARAVAN
VIEW MORE
SPONSORED LINKS
Catalytic Converter Test
Online car repair manuals
