2003 Dodge Caravan ABS, traction control lights on.
2003 DODGE CARAVAN
93,000 MILES • 6 CYL • FWD • AUTOMATIC
SEESKO
The Cruise control on my Grand Caravan has not worked for a while. The Abs and traction control dash indicators came on a while after that. 6 or 7 months ago. I was told it could be wheel speed sensors. Is there one on each wheel? Do I need code reader to find out which sensor it might be?
thanks
Dec 9, 2009 at 6:27 AM
BMRFIXIT
  • 19,053 POSTS
Yes you have a sensor per tire
code reader will not help what you need a scanner to access the ABS module and communicate with it for codes
as for the cruise not working check and suspect clock spring
Dec 9, 2009 at 10:47 AM
