2003 Dodge Caravan ABS Light
CCI
  • 6 POSTS
Brakes problem
2003 Dodge Caravan
I have noticed the ABS light coming on intermittently but doesn't stay on for long. The brakes seem fine. I noticed the fluid is a little low so I topped it off. The light hasn't come back yet but it comes and goes in longer periods than this. Would low levels of fluid cause this? Should I be more concerned.
Mar 1, 2010 at 10:07 AM
BMRFIXIT
  • 19,053 POSTS
Low fluid will cause the brake light to be on
and need to be checking the brakes (pads low or rear shoes )
ABS light on system need to be scanner for codes
Mar 1, 2010 at 10:20 AM
