2003 Dodge Caravan 2nd gear
133,111 MILES • 4 CYL • 2WD • AUTOMATIC
KENT STARCHER
I have these code # 0700, 0733, 0732, 0736 do you know what these means I took my van down to Auto Zone in 2nd gear and got the codes. it won't
come out of the safe mode unless I take the ground
wire lose and wait couple of hour and it will work
good for about 5 miles and then go into the safe mode.
I replace both input and output sensor and them didn't help.
I took the van down to the local transmission shop
and they told me that they can fit it for $1850.00
Sep 15, 2010 at 5:43 AM
  • 110,251 POSTS
I recommend another opinion. It sounds like a bad TCM (trans control module). Have that checked. It is around 200.00 to replace.
Sep 17, 2010 at 12:12 AM
