2003 Dodge Caravan 2003 Dodge Caravan idles fine pecks when
2003 DODGE CARAVAN
157,000 MILES • 6 CYL • FWD • AUTOMATIC
LILLYBEAN
While it's just idling, it sounds perfect. But when you go to give it the gas, a loud pecking noise sounds like it is coming from the top part of the engine. Just suddenly started happening one day on the way home. Also rattles a bit when it starts.
Mar 14, 2010 at 2:06 PM
LEGITIMATE007
  • 5,121 POSTS
sounds like a rod is knocking., check the oil level and top off, see if it makes a difference, if not, the rod will need to be replaced
Mar 23, 2010 at 5:26 AM
