2003 Dodge Grand Caravan AC Drain Leak Fix
CARAVAN TO SPRINTER
2003 grand caravan sport(bought as new 01/2004)
3.3l engine
52k miles
with rear a/c
mobil 1 oil and regular air filter changes
HAS BEEN VERY DEPENDABLE
Nuances are: (major issue is below)
-sluggish exceleration, past 10,000 miles
-ticking type of sound coming from idler pulley area when cold, goes away when warmed up.
-fairly minute shudder when trans shifts in low gear. I have felt it from day one but no one else could (dealer mech. included)
REASON FOR POST!!!
Water seems to be leaking from the interior side of where the drain goes through the firewall(soaked carpet. On the exterior side the drain looks incomplete. It is a hard plastic tube sticking out of the firewall about an inch long with a slot cut into the under side of it. It looks like it should have a rubber elbow on it or something. The water that does come out the ext. side seems to run back to the firewall insulation and then down. I need to know how bad the problem is or is it just a clog situation. I did try some compressed air and the air went through but did not stop the interior leak.
Thanks for any help.
Rick
Jun 4, 2007 at 1:25 PM
E40WATER12
  • 522 POSTS
The A/C drain hole hose could have a defective piece, In which leaks into the van, in stead of leaking outside the firewall. Could just get another piece of hose the same size and it should fix that problem.
Jun 7, 2007 at 7:47 PM
Suggested Repair
Replace the A/C evaporator drain hose at the firewall with a same-size hose so condensate drains outside instead of into the cabin.
Conversation Summary
The owner of a 2003 Dodge Grand Caravan reports water soaking the carpet near the firewall A/C drain. The exterior drain is a short slotted plastic tube, and water runs back toward the firewall insulation. Compressed air passed through but did not stop the interior leak. The expert says the drain hose may be defective and leaking inside, and replacing it with a same-size hose should fix the problem.
